Dynatrace Managed integration with Azure AD
These instructions describe how to setup Azure as the IdP for Dynatrace SaaS:
https://www.dynatrace.com/support/help/how-to-use-dynatrace/user-management-and-sso/manage-users-and...
The SAML documentation for Dynatrace Managed doesn't contain any Azure-specific instructions:
https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/users-and-groups-se...
Is it perhaps only overlooked, or is there a reason to believe that Azure AD integration with Dynatrace Managed would not work?
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Dynatrace Managed works with all SAML-based Identity Providers. Azure AD is just one of them, and we have customers that integrated that well. In our documentation, we showed an example how to configure with Microsoft ADFS - as that was most frequently asked and widely used in enterprises. As Dynatrace SSO also works with SAML - instructions might be similar.
Thanks for posting that idea. We'll think if to include Azure example as well for Dynatrace Managed.
Senior Product Manager,
Dynatrace Managed expert
Thanks! That's what I assumed, but wanted to double-check in case I missed something here 🙂
