question
Davide D. avatar image
Davide D. asked ·
Siteminder monitoring
is there a way to monitoring Siteminder with dynatrace ? Is this tecnology supported ?
monitoringtechnologies
Peter R. avatar image
Peter R. answered ·
most of site minder is just java. We use the one agent to monitor. you can also enhance with extracting JMX metrics.
if your dealing with the SMPolicy servers, Please note that it is extremely important to load test this. Extracting metrics can lead to exponential performance impacts.
1 comment Share
Thanks for the comments Peter! I'm also about to implement some monitoring for Siteminder in the future, so this is good stuff to know.
0 Likes 0 · ·
Chad T. avatar image
Chad T. answered ·
Its worth a shot to try out. if you cant use the Oneagent on it, you can always monitor it via angentless.
Share
