Is there An API that triggers the upgrade of the OneAgent to a specific version for a given hostName?
morsi_tlili
Participant
Is there any API that can trigger the upgrade of the OneAgent to a specific version for a given hostName?
DavorinKrivak
Helper
Hi Morsi,
You can use the Version element of the HostAutoUpdate object to specify the agent version for a particular host id: https://www.dynatrace.com/support/help/shortlink/api-config-oneagent-on-host-auto-update-put#hostsid...
DJ
