Dynatrace Synthetic - Is there host file mechanism
chuan_sern_wong
Advisor
I am trying to test out with and without CDN and do not want to go into creating a CName at thos stage. Is there a way for me to define a host file with Dynatrace Synthetic ?
AntonioSousa
If you are using the public agents, that is not an option.
If you have private agents, eventually you can mess around with DNS/hostFiles, but that should be done carefully...
Antonio Sousa
