question
dynatrace A. avatar image
dynatrace A. asked ·
How to setup JBOSS to show Active thread count/ %use metric like as WebSphere Active thread metric?
Hi everyone
Please, suggest us about How to setup JBOSS to show Active thread count/ %use metric like as WebSphere Active thread metric
We have been trying to use JMX custom metric but not found that metric.
Maybe, we must enable metric something on JBOSS like ConnectionPool?
Information,
JMX custom metric will setup
WebSphere Active thread count metric
Best regards
Askme solution Thailand
oneagentjava
1 Answer
Chad T. avatar image
Chad T. answered ·
If you go to create custom chart and select Custom as the category, then type in Jboss you should see everything that you can use:
If these are not viable options, you might need to look into putting in a RFE to allow you to chart those metrics.
https://answers.dynatrace.com/content/idea/post.html?space=483
Share
