How to Monitor SAP FIORI in On-Prem
tarun_kumar_aga
Organizer
We would like to monitor SAP FIORI on-prem system with dynatrace and didn't find any relevant document for setting up RUM setup.
Only documentation I found is for Cloud Fiori monitoring.
https://blogs.sap.com/2018/07/17/monitoring-a-fiori-launchpad-on-sap-cloud-portal-using-dynatrace./
Can someone please hlep us how to setup for On-prem .
Tarun
sia_h
Dynatrace Pro
Dynatrace Pro
Hi Tarun,
In general it works the same way as the Cloud version mentioned in the SAP blog.
You can set up agentless Real user Monitoring. The only difference is that you'll have to implement the RUM-JavaScript tag or Code Snippet somwhere on the on-premise Application so that it is served in all pages presented to the end-user.
Sia
