08 Jun 2020 08:32 AM
Dear All,
How to get the information on the thread of IBM Integration Bus?
Threads set at flow level inside the integration server, which is called the execution group running on the Integration Node called the broker.
Babar
28 Jul 2020 02:56 PM
You might need to use a custom plugin for this information
