How to read code level on pure path
andra_nosa
Helper
How to read code level on purepath,
I am very confused how to read it,
For elapsed time, self time, and duration
Julius_Loman
DynaMight Legend
DynaMight Legend
  • Elapsed time shows the time the instrumented point in code started execution (calculated from the beginning of the purepath, so first entry will have zero time)
  • Self-time shows the duration of the code itself (the instrumented row), excluding subcalls
  • Duration shows the duration of the code itself including subcalls.
Hi Julius L,
Thanks for your answer
ANP
