Dynatrace Browser Monitor Token
sanjiv1987
Guide
How to create a Dynatrace Browser for a file share endpoint. The fileshare end point has the token details for authentication.
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Have you already checked advanced configuration of browser monitors: https://www.dynatrace.com/support/help/shortlink/browser-monitors-config#advanced-setup- ?
I guess you can use credential vault and HTTP headers to authenticate.
Senior Product Manager,
Dynatrace Managed expert
