OneAgent Download through the API
If this sufficient to download oneagent
wget -O Dynatrace-OneAgent-Linux-[version].sh https://[serverURL]/installer/agent/unix/latest/?api-token=abcdefjhij1234567890
I'm just passing api-token as query in url, but document says we need PaaS token for downloading the oneagent, if so how to add PaaS token can you give me an example which helps me to download the oneagent from my Managed server.
sia_h
Dynatrace Pro
Dynatrace Pro
Hi Ravi,
Instead of an API-token please use a PaaS-token in your request:
curl -X GET "https://abc.dynatrace.com/api/v1/deployment/installer/gateway/windows/latest" -H  "accept: */*" -H  "Authorization: Api-Token PAAS-TOKEN-HERE"
It may indeed look confusing but if you look in the Swagger API UI you'll see that they're asking for a PaaS-token instead of the standard API-token that we usually use.
Sia
