Turn on Global request naming rules
henk_stobbe
DynaMight Champion
DynaMight Champion
I have created multiple naming rules in the API but it seems I can not enable them:
This is on global and on the service level, in the JSON "enabled":true is defined.
Am I missing anything?
KR Henk
3 REPLIES 3
henk_stobbe
DynaMight Champion
DynaMight Champion
Found it, is is already activated. But you can not switch is off. But please be careful with this. The services where a match is made:
Response time degradation
The current response time (544 ms) exceeds the auto-detected baseline (6.59 ms) by 8,150 %
The current response time (393 ms) exceeds the auto-detected baseline (11 ms) by 3,470 %
I hope this is only the case when switching in on, but could not wait for this )-;
After removing the rules in the API everything is ok again (-;
Please notice current response xxx ms baseline X.XX and the increase X,XXX, so the first is rounded, the second value has a dot and the percentage has a comma?
KR Henk
Talked to Dynatrace, the switches can not be used by design,
KR Henk
ChadTurner
DynaMight Legend
DynaMight Legend
Thanks Henk, yeah I was going to say that appears to be already on. It might take a few mins for the rules to apply.
Thanks for the feedback as well and the tips and tricks you discovered while working with the API!
-Chad
