Monitoring of AWS Direct Connect
andre_vdveen
DynaMight Champion
DynaMight Champion
Is it possible to monitor AWS Direct Connect in Dynatrace? I checked the options for the monitoring of the additional service, but it is not listed there. It can be monitored via CloudWatch, but I don't see the integration option in Dynatrace so I guess not.
Is this something that's planned?
alexandre_marl2
Organizer
At perform 2020 conference they announced a full integration of all AWS and Azure metrics inside dynatrace in Q2 2020.
So it should be coming very soon 🙂 I can't wait !
Alex
deepti_thapliy1
Dynatrace Enthusiast
Hi There,
We are trying to monitor AWS Direct Connect running on Megaport for a Customer, but no luck.
Would have thought the 'Direct Connect' Virtual Interface metrics would pick this up but getting no data. Nothing in logs regarding the 'Direct Connect' Service, IAM is correct and other services (route 53, vpc nat, transit) are working fine.
Any idea if a setting specific to Megaport is required or just describing connection for direct connect should ideally work?
(as per the steps share here)
Deepti
