Most user sessions appear anonymous
pierre_boucher
Newcomer
Although I always use the same page template containing the js variable that I defined as a user tag, most user sessions are anonymous.
It seems to have been happening since mid-March.
How can I check if the user value is correctly seen by DT js?
5 REPLIES 5
zietho
Dynatrace Champion
Dynatrace Champion
Hey,
don't tell anybody but we are working on something visual to help you validating these things more easily in your client in the near future.
In the meanwhile I can offer you to use:
dtrum.getAndEvaluateMetaData();
cheers
Thomas
There seems to be no documentation on getAndEvaluateMetaData()
What does it do?
Antonio Sousa
Hi @Antonio S.
Documentation on dtrum you can fin under Settings --> Web and mobile monitoring --> Advanced setup
Extract the zip and look under doc for the index.html
you will find all the information you need for dtrum and also for getAndEvaluateMetaData
HTH
Yos
Thanks Yos,
I had done a simple search in Google for the whole Dynatrace domain, and this was the only link.
Antonio Sousa
ChadTurner
DynaMight Legend
DynaMight Legend
As Thomas stated, using:
Should help you out a bit.
-Chad
