Is there any limit of length of URL path to pre-processed and/or processed during configuration of request attribute?
I try to extract username for the long URL to be a request attribute, the username is almost the end of the long URL.
After a few round of trial and testing using the 'sample test string' box, it seems like it can only process a certain amount of character.
Is that true? can anyone confirmed?
or has anyone ran into this problem as well?
Best Regards,
Wai Keat
ChadTurner
DynaMight Legend
DynaMight Legend
@Chan Wai K. the limit is 1K - We have confirmed this with support. Hope that helps. If you are still running into an issue while being under the 1K limit, I'd open a support ticket.
-Chad
