Dynatrace component to monitor around 20 hosts ?
m_nasrudin1
Guide
I'm still learning about Dynatrace, and I want to plan build a Dynatrace Managed for on premises, but still confused what kind of the Dynatrace components are used to monitor around 20 hosts and Mobile RUM. Is it correct when I'm prepare 2 server for Dynatrace Managed Cluster and Cluster ActiveGate (to monitor Mobile RUM) ?
And how much storage that I can prepare to store the data around 30 days ?
I used Appmon before, I think so many difference between Appmon and Dynatrace
Nasrudin
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
At minimum to monitor external Mobile RUM and 20 hosts - you'll need 1 Dynatrace Managed node and 1 Cluster ActiveGate.
See hardware requirements: https://www.dynatrace.com/support/help/shortlink/managed-requirements#hardware-requirements
You will need 1 "Trial" node - actually the name will be changed soon to "Micro"
This is also how you deployment scenario could look like:
https://www.dynatrace.com/support/help/shortlink/managed-deployment-scenarios#scenario-2-pure-dynatr...
Senior Product Manager,
Dynatrace Managed expert
