Hi Team,
We have installed Dynatrace oneagent on Solaris nodemanager server for which the host is going to unmonitored state after 15 mins and again coming back to monitored state after 1 day. This happened for 6 solaris hosts out of 10 and we installed on 3 hosts a day and the same issue occured two days. We thought it is unable to communicate with Active Gate but after seeing the logs we could see there is a connection established. Then what is making the host going into unmonitored state and coming back to monitored state automatically after a day.
Please suggest what may be the root cause for this issue.
Thanks&Regards,
Rosy
Answer by Wolfgang B. ·
Please create a support ticket for that situation, this does not match the designed behavior.
Wolfgang
Answer by Rosyland D. ·
Log.txtHi,
There are no firewalls blocking the connection. If I see the agent logs I found the following attached:
Can you please tell what is making the agent inactive and active again automatically?
Thank you for providing the log. I would open up a support ticket. Are you using a DEMO version of Dynatrace? Can you check and ensure your trial is valid or if you have purchased dynatrace, that you have enough licenses for host units/hours? Have you tried to uninstall and reinstall the oneagent? what version of the oneagent are you using? what version is your cluster at?
Rerount RUM data to AG instead of our web server
How to check if Oneagent is reporting directly or via ActiveGate to my SAAS CLuster
Upgrading policies on Active Gates, Nodes, and OneAgents. When is mandatory to upgrade software ?
Does Dynatrace SaaS need to call Environment ActiveGate over internet?
Support on the roadmap to monitor Dell-EMC VNX5800 in Dynatrace?
