question
Josep C. avatar image
Josep C. asked ·
JVM metrics in a single chart for several processes
Hi all,
we've several java processes in my system and I want to review some JVM parameters for all of these processes.
I can see all those metrics in the "Process metrics -> Java managed" metrics section but only process by process not in a single char splitted by process.
So, how can I view these metrics in a single chart split by process instance?
Thanks in advance!
java
1 Answer
Yos N. avatar image
Yos N. answered ·
Hi @Jose C.
Please check the JVM metrics under custom charts
And for JVM metrics under infrastructure information of Timeseries v1 Available metrics
HTH
Yos
3 comments Share
Great answer Yos!
Only thing I would add is to look into using the Metrics API instead of Timeseries. Timeseries will eventually be deprecated and the Metrics API is much more powerful.
https://www.dynatrace.com/support/help/dynatrace-api/environment-api/metric-v2/
Ari
2 Likes 2 · ·
Hi @Yos N.,
thanks for your response, I'm interested in GC Collection count and GC Collection time but I want to view in a chart.
Regards, Josep Maria
0 Likes 0 · ·
You can use custom charts for that as well similar to Yos' screenshot.
Ari
0 Likes 0 · ·
