Could Dynatrace pull FogLight for Database metric to show on Dynatrace dashboard?
Hi everyone
Foglight agent conflict Dynatrace Agent then they would like to show Foglight metric on Dynatrace.
So, I would like to pull FogLight for Database metric to show on Dynatrace dashboard
They have used Foglight for Databases Cross-Platform 5.9.xxx
Foglight Cartridge for DB2 5.9.xxx
Best regards
Askme Solution Thailand
michael_oxendin
Dynatrace Helper
Dynatrace Helper
The first solution I have to do this would be through a custom metric.
First create a timeseries ID for the metric you are interested in, in this case the database metric.
Then, create a custom device to assign the custom metric to.
Finally, extract the metric from foglight that you are interested in through whatever methods are available, and push them into dynatrace with a POST request to the custom device created.
Michael Oxendine
Hi Michael
Thanks for your suggestion
Best regards
