swarm container status
Yosi_Neuman
Hi guys,
Customer running swarm environment and ask if there is a way to check the status of the container if its show as healthy or stack in starting or good for sake unhealthy
Here all the containers are shown as healthy but there are cases that the management containers (ucp-*) stack in starting or unhealthy and their entire site is down.
Question is if dynatrace can catch this statuses OOTB or we need to create one agent plugin that will some how fetch the state of the management containers and look for the not healthy ones?
Will be happy to read your comments
Thanks in advance
Yos
ChadTurner
DynaMight Legend
DynaMight Legend
I am not sure if Dynatrace can do this OOTB, but if not, you can always build a plugin that grabs this data or have Dynatrace build the plugin. Let us know what you are able to find out!
Here is a link to the supported Technologies and Versions: https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/
-Chad
branedalAditro
Visitor
Hi! Interesting post! Did you get some solution to this?
