Dynatrace Managed Installation directory in linux
m_nasrudin1
Guide
I have a plan to install Dynatrace Managed in linux, in the documentation default setting is like this :
  • Installation path (binaries): /opt/dynatrace-managed
  • Dynatrace Server data files: /var/opt/dynatrace-managed
Can I customize this installation directory ? lets say I want to point the Dynatrace Server data files to /opt directory
3 REPLIES 3
AntonioSousa
I'll just add an example to make this answer 100% complete:
To configure data storages:
./dynatrace-managed-installer.sh --datastore-dir /opt/dynatrace-managed-data --rpl-datastore-dir /opt/dynatrace-managed-data/session-replay --cas-datastore-dir /opt/dynatrace-managed-data/cassandra --els-datastore-dir /opt/dynatrace-managed-data/elasticsearch --svr-datastore-dir /opt-dynatrace-managed-data/transactions
Or just run the installer and specify new paths in the interactive mode.
Senior Product Manager,
Dynatrace Managed expert
It appears that the link provided in Antonio's answer is no longer functional. Here's the updated link:
https://docs.dynatrace.com/managed/shortlink/managed-custom-install
