USQL-based dashboard tiles position and size reset
marc_zantingh
Frequent Guest
Every time I change the underlying query or even the title of a USQL-based dashboard tile, its position and size reset. Is there any way to prevent this?
5 REPLIES 5
justin_hogue
Dynatrace Advisor
Dynatrace Advisor
I'm not sure what's causing this or of a fix at the moment, but it is something that is being looked at internally.
Best regards,
Justin Hogue
RomanW
Dynatrace Champion
Dynatrace Champion
Thanks for the feedback! This has been looked at and fixed in the meantime.
Hi Roman, thanks for the response. Unfortunately, it does not seem to be fixed, behaviour is still the same after updating the USQL. I even created a new dashboard to make sure, but there the same thing happens.
Which version are you on? The fix should come with version 1.198.
Hi Roman, we've updated to 1.198 and now the issue doesn't occur anymore. Thanks!
