Ping, port checks, and DNS lookups
AntonioSousa
Dynatrace has announced the ability to do ping, port checks, and DNS lookups:
https://www.dynatrace.com/news/blog/monitor-your-whole-infrastructure-using-synthetic-monitors/
It uses Activegate Extensions, but is positioned as synthetic monitoring.
Does anyone know if it consumes DDUs or DEMs?
Antonio Sousa
Mike_L
Dynatrace Guru
Dynatrace Guru
Hi Antonio,
Third-party synthetic results (which is the API used) consumes 0.1 DEM units per measurement. This is the help page which has the information: https://www.dynatrace.com/support/help/reference/monitoring-consumption-calculation/#digital-experie...
Mike
Mike
Nitesh_DynaMon
Newcomer
no
