Request Name name case insensitivity
I64963
Newcomer
We have a public API and no control of the casing that clients use when using the API. The problem that we see is the '/api/project' and '/api/Project' are treated as different requests. We've used request naming rules as a workaround for this but that feels like a very clunky solution as we have to do them individually for each request that we care about.
Is there a way to turn off case sensitivity for detected web request names for a service?
5 REPLIES 5
Radu
Dynatrace Champion
Dynatrace Champion
Hi Brian,
With request naming rules you should be able to go service by service (using the UI) instead of request by request. You can create a cleanup rule that extracts the request name as is and converts it to lower case. Go to your Service > Edit > Web request naming rules > add Cleanup rule:
If you have a need for this for more than a couple of services, the API is the alternative for creating these rules at a global level.
.../api/config/v1/service/requestNaming
I hope this helps.
Best regards,
Radu
Radu, this is not solution.
It doesn`t work.
It transfer all URL to "/" - I have requested "/pDp/2222/dRd" and "/ppp/2222/ddd"
It can be done  by rule with additional placeholder:
Result:
Alexander
This is great, but by doing this it removes the clean up rule `Remove UUIDs, IP addresses and IBANs from URLs`
Do you have a way how we can fix this ?
You can apply the placeholder on the request name rather than the URL path to preserve [uuid] and similar replacements that Dynatrace already performed.
In case of non-URL request names, I use a broader match of regex:  (\S+?)$
I have this same issue and would really appreciate a global way to turn off case sensitivity on all requests. It has to be at least by service and I'd appreciate it if it was simply a check box at the global or service level. It's very much a pain to try and do this at a request or service level now.
