Dynatrace Managed - update tenant transaction storage settings via API/command line
Need some help - hit the wall here.
We have a very heavily utilized DT managed cluster with >2200 environments and 15 Large cluster nodes inside it. When going to Gui --> Environments, it times out - I waited for 1h, 10h, any time of the day/night - result always the same.
I need to update the Transaction Storage settings for one tenant. I tried to use a shortcut -
https://our.cluster.id/cmc#cm/environments/envDetails;envId=our-tenantID;gf=all but it times out as well.
I see at the Cluster API documentation
https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/cluster-api/dynatra... it lists:
Environments
List all existing environments
Create new environments
Get properties of specified environment
Update existing environment
Delete specified environment
I have a slight suspicion that the above might help me but these calls are not documented.
I need to have means to do the task - via API/command line, etc - I don't care.
Please help.
Thanks.
3 REPLIES 3
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Hi Irakli,
your cluster has a way more environments than we support. Simply the cluster is overloaded that's why the time-outs occur. I think we may help you with setting this up - please open a support ticket for that.
REST API you mentioned does not expose configuration of transaction storage. This will come in the future.
Senior Product Manager,
Dynatrace Managed expert
@Radoslaw S.
Thanks for replying. What is the timeline for supporting such changes via API?
I'll check with my folks to open a ticket.
CQ1/2021 I hope
