Incorrect encoding of host metadata on Windows using oneagentctl
grechnev
Participant
As stated in the Documentation there are two ways of setting host metadata: oneagentctl --set-host-property command (recommended) and hostcustomproperties.conf file:
https://www.dynatrace.com/support/help/shortlink/tagging-hostautotag#edit-the-host-tag-configuration...
The file must be in UTF-8. But if we use oneagentctl.exe on Windows machine, it writes the file automatically in default windows encoding. See the screenshots:
After manual converting the file to UTF-8 it becomes correct:
Is it a bug?
3 REPLIES 3
ChadTurner
DynaMight Legend
DynaMight Legend
This is very interesting and I would classify this not as a bug but maybe an oversight. Im going to raise this up to support so they are aware of this issue.
-Chad
Support is reaching out to the PM Team on this
-Chad
Tomasz_Gajger
Dynatrace Champion
Dynatrace Champion
Hi Max,
this behavior looks unexpected, we're looking into it internally.
If you want to get further updates on the case please open a support ticket or use in-product chat and refer to the ticket number APM-253054.
Tomasz
