SCIM support in Dynatrace Managed
I can see thar SCIM support for Dynatrace SaaS is in early adopter at the moment (August 2020).
Any plans to support SCIM in Dynatrace Managed?
/Thomas
ChadTurner
DynaMight Legend
DynaMight Legend
If it is in early adopter then I would expect it to go GA at some point for both SaaS and Managed. Keep in mind that Managed is always 2 weeks behind SaaS as well. You can always toss in a RFE to ensure that they are aware of the need for this feature in Managed,
-Chad
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
There are no plans to support SCIM for Managed at the moment. This is first time I hear the requirement. What would you like to integrate with ?
Senior Product Manager,
Dynatrace Managed expert
