Downtime during update of Dynatrace Managed
Hi everyone,
The customer has a question. If they have Dynatrace cluster 3 nodes when Dynatrace update.
1 Have Dynatrace has downtime for using Dynatrace Web UI or Dashboard?
2 How long Dynatrace update takes time and cannot use Web UI and Dashboard?
3 How does solution reduce downtime minimize If Dynatrace update has downtime?
Best regards
Askme Solutions Thailand
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
If there are 3 or more nodes, upgrade is done at a one node at a time in a rolling fashion (one by another). Dynatrace is fully functional when 1out of 3 nodes are down. No downtime is expected.
Senior Product Manager,
Dynatrace Managed expert
Hi, Radoslaw,
Thank you for your detailed information.
That is very helpful.
Best regards
