ACI Monitoring
SESA284306
Newcomer
Can Dynatrace OneAgent monitor ACI's. Is there a reference document ?
ChadTurner
DynaMight Legend
DynaMight Legend
Here is the support doc with the supported technologies. Keep in mind you can always try and use agent less monitoring as well if the oneagent will not support your tech.
https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/?_ga=2...
-Chad
