Message size of the Client-side
Babar_Qayyum
Dear All,
What is the message size of client-side metadata (Bytes or Kilobytes)?
Babar
3 REPLIES 3
Julius_Loman
DynaMight Legend
DynaMight Legend
I believe this is definitely in bytes when looking at values in one of our environments. But units should be added for exactness.
Hello @Julius L.
Thank you for the comments. Can I consider it bytes or sill we need to be sure?
Babar
Probably a question for a Dynatrace PM or developers. But seeing the values I hardly can think of other units than bytes.
