Postman for effortless Dynatrace API access across environments
pahofmann
I've been updating Postman collections for myself for a while to make it easier to work with the Dynatrace API across multiple clusters, tenants, and environments.
I have put the files on github now, maybe someone will find it useful.
Setup is very quick, then you can just select the request and environment against which to execute it.
Here is a short guide:
  Import collections
Postman is available for free from postman.com.
Import (file -> import) the collection .json files for the APIs you want:
A separate collection for each, including all requests of that API, will be created:
    Create environments
For each of your Dynatrace environments/tenants you want to use, add a postman environment via manage environments -> add:
The environment needs two variables (names are case sensitive!):
  • DT_HOST
    • URL to the environments
      • For managed: your-dt-domain.com/e/Environment-ID
        • example.com/e/b80b158e-ev23-4330-30fcc-c4391bbx6ce2
      • For SaaS: Env-ID.live.dynatrace.com
        • abc133769.live.dynatrace.com
  • DT_TOKEN
    • An API token for the environment
new-environment
    Request away!
Now you can open any request and easily execute it against different Dynatrace environments by selecting the environment on the top right: Dynatrace API Postman Collections
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
27 REPLIES 27
AntonioSousa
This seems very interesting! Going to check it out when I have a little time.
Antonio Sousa
Malaik
DynaMight Champion
DynaMight Champion
Thanks @pahofmann for sharing, sure will be useful.
I cant find the way to get the json files.
Sharing Knowledge
You can get from from the API Explorer.
Malaik
DynaMight Champion
DynaMight Champion
Hi @pahofmann ,
How can I download the collection from the github ?
Sharing Knowledge
The collections are saved as .json files in the repository.
You can either copy them from the specs folder or just download the whole bundle from the releases page.
Malaik
DynaMight Champion
DynaMight Champion
Thanks a lot man
Good day 🙂
Sharing Knowledge
pahofmann
Updated to 220, including cluster APIs.
pahofmann
With one of the recent Postman version the UI changed a bit.  The environments can now be found in the left side menue:
Malaik
DynaMight Champion
DynaMight Champion
Yes, i used this version after my last post
Thanks or your update.
Very Useful
Sharing Knowledge
pahofmann
Latest Release updated to Version 1.226 (Cluster API 1.224)
theharithsa
Dynatrace Champion
Dynatrace Champion
It was very much helpful and this acts as a utility to have. It saves a lot of time while working with customers.
Thanks for sharing.
Love more, hate less; Technology for all, together we grow.
pahofmann
Updated to 1.234: Github Link.
wim_muselle
Visitor
top nodge, we are currently working on an API v2 version for integration to Splunk , having this so visual in postman really helps. works like a charm.
pahofmann
Update to 1.248: Github Release Link.
Also automated the process so future updates can be more frequent or be done by the user if in a hurry.
pahofmann
Updated to 1.250: Github Release Link.
Also there is a Insomnia Version now: Community Thread Github
hi @pahofmann the links on your initial page are now not working (404), I guess because of the update? (pahofmann/dynatrace-postman-collections: Summary of postman collections for all dynatrace APIs. (git...
Kind regards, Frans Stekelenburg                 Certified Dynatrace Associate | measure.works, Dynatrace Partner
Thanks, updated 🙂
Thank you x 2 ! 🙂
pahofmann
Updated to 1.258 (Environment) and 1.256 (Cluster): Github Release Link
pahofmann
Updated Env and Cluster to 260: Github Release Link
Thanks for keeping this updated.
The true delight is in the finding out rather than in the knowing.
ct_27
DynaMight Pro
DynaMight Pro
@pahofmann  thank you for maintaining this and please keep posting as you make updates. This is a very useful solution you've created here.
HigherEd
Thanks, always nice to hear. Will do.
pahofmann
Update to Environment 1.270 and Cluster 1.268: Github Release
pahofmann
Updated to Environment/Cluster 1.274: Github Release.
Profile_Myself
Newcomer
@pahofmann Firstly thanks for this its to truly helpful. Is there a way I can get the metadata / manifest file for the API's. In OCI DI you have to create a REST API task that requires you to add a json or yml manifest file for the API you calling.
Great to hear it helps. Sorry for the late reply, I was on vacation 🙂
You can download the OpenAPI Spec file for the dynatrace API directly from your environment.
Just go to the API browser (via person icon on the top right), there you have the option to download the spec.json:
