Can we change time zone UTC to IST in OneAgent
tushar_dhule
Participant
After subscription dashboard we are receiving report email in night I guess as per UTC time zone. Can we change that to IST timezone.
4 REPLIES 4
ChadTurner
DynaMight Legend
DynaMight Legend
Unfortunately at this time you cannot change when the subscription emails are sent out. They are sent out at midnight UTC and at this time it is not configurable.
https://www.dynatrace.com/support/help/how-to-use-dynatrace/dashboards-and-charts/dashboards/subscri...
-Chad
I am ok if it trigger in midnight but can't we change UTC to IST midnight.
At this time no. The ability just does not exist. I would recommend putting in a RFE is this is a feature that is needed. https://community.dynatrace.com/t5/forums/postpage/board-id/DynatraceProductIdeas
-Chad
Thanks for your suggestion.
