Python Requests fail
Lisa_Singh01
Participant
I get an invalid syntax trying to use the requests library in Python. I've used the same syntax as this: https://community.dynatrace.com/questions/241885/how-to-get-data-from-dynatrace-api-using-python-re....
import requests
URL = "https://somehostname.live.dynatrace.com/api/v2/metrics/query?metricSelector=builtin%3Asynthetic.browser.totalDuration&from=now-2d&to=now-1d")
headers = {'Authorization': "Api-Token " + 123456Token123456}
r = requests.get(url, headers=headers)
print(r)
But get invalid syntax errors:
Traceback (most recent call last):
  File "C:\Users\leica\Documents\Python\muckingabout.py", line 3
SyntaxError: invalid syntax
Mike_L
Dynatrace Guru
Dynatrace Guru
Please remove the trailing ')' from your code on line three (the end of the URL) as it fails to compile due to that one.
Once that's resolved it will also fail on line 4 as the API token needs to be within the quotes, it's not a variable.
Mike
Mike
