World Map in Dashboard is not fetching the data
manidharreddy_y
Newcomer
The world map doesn't show up the data in dashboard. whereas it shows the data in the application . Is there any issue or any limitation.
3 REPLIES 3
larry_roberts
DynaMight Champion
DynaMight Champion
Good morning,
Could you provide a couple of screenshots?
A couple of things come to mind...
  • Ensure the settings for the world map tile are correct.
    • Make sure the current application has been selected as well as performance and behavior.
  • Ensure that the Management Zone and timespan is set correctly at the top right of the screen.
  • Ensure the correct configuration of the dashboard settings.
Hope that helps!
manidharreddy_y
Newcomer
Hello Larry,
Please find the screenshots below
The dashboard tile (world map) shows no data but if i click on the tile it re-directs me to the application and shows me the data in world map there.
Just to clarify... The yellow area, is that just a blur you added or is that actually showing up in the map tile? It was somewhat hard to tell.
Also, could you provide a screenshot of the tile settings?
If you are attempting to get the same visual seen here:
you will want to make sure that within the tile settings you have selected "S4 HANA" as the application and "User actions".
