Automatic memory dumps in case of alert
balazs_horvath
Newcomer
We have the latest ActiveGate installed, dumps are enabled there, and we created some alerts, if the memory consumption goes over x %. Is it configure somehow to trigger an automatic thread dump for this event, or in any other way?
Thanks in advance!
Balázs
ari_polavarapu
Dynatrace Champion
Dynatrace Champion
Hi Balazs,
This isn't possible at the moment.
However, I would recommend looking into the Continuous Memory Profiling functionality to help with your use case.
More info on this blog post -> https://www.dynatrace.com/news/blog/radically-speed-up-your-code-by-fixing-slow-or-frequent-garbage-...
Hope that helps.
Ari
