API REST for problem with custom alert
jose-antonio_ra
Inactive
Hi all.
I have a custom event for alerting, which I use for an alerting profile. My idea is to be able to consult the problems through the API:
api/v1/problem/feed
but if I run this request in the returned json I don't have the event description, and that information is important to my company.
Can someone help me with this? In summary, I need to check with the API the problems that occur and see the description of the custom poison that triggered it.
Thanks in advance and greetings
3 REPLIES 3
JamesKitson
Dynatrace Guru
Dynatrace Guru
The problem feed doesn't include everything, you can make a second call with a specific problem ID to get all of the details about the problem that are exposed through the API:
https://www.dynatrace.com/support/help/dynatrace-api/environment-api/problems/problems/get-details/
This would include everything you have to work with so hopefully that would have what you need.
Thanks JAmes.
But I need the information of the message that is sent to the receiver of the event.
i´ve try with:
/api/v1/events/*******
/api/v1/problem/details/*********
Any idea how to do it ??
Regards
Jose A
jose-antonio_ra
Inactive
Finally, the support team tells me that it is not possible to receive that information.
I have created this RFE
Thanks for your answer @James K.
