Can we enable access to Dynatrace Managed UI post license expiry date?
sumit_patil
Participant
Hi All,
Can we able to access Dynatrace Oneagent Managed UI post license expiry date?
I can confirm that with the latest few versions of Managed you indeed can. For a while it was so that the UI is fully locked after license expiry, but now it's available again. So you can still see the history data, you just can't keep any monitoring running.
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
In Dynatrace Managed UI should be blocked after 30 days passed from license expiration date.
Senior Product Manager,
Dynatrace Managed expert
