Synthetic Monitor Validate Dynatrace API Header Count
Need a Help to validate Dynatrace API header Count Validation Via Java Script under the Synthetic Monitoring.
1) Dynatrace API Calls:
'https://XXXXXXX.live.dynatrace.com/api/v1/entity/infrastructure/hosts?Api-Token=************&tag=Environment:pd_Cloud'
2) JSON Header Output
We need to Validate the Count - Eg: We need alerts if the server count is less or Greater than "43"
3) We have tried in the below pages with the Javascript.
ChadTurner
DynaMight Legend
DynaMight Legend
I see what your trying to do but im not too sure if that is possible in the product. Anyone have any suggestions?
If you dont get any additional replies I'd recommend tossing in a RFE and if this is available in the product now, support will guide you in setting that up 🙂 and if its not available, hopefully they can build it in!
-Chad
