Is there documentation on how to send metrics to Dynatrace over StatsD?
grogers
Contributor
I'm excited after reading the recent blog post on pushing custom metrics into Dynatrace (https://www.dynatrace.com/news/blog/dynatrace-simplifies-statsd-telegraf-and-prometheus-observabilit...)
Are there instructions for how to sent StatsD metrics into Dynatrace? I'm not able to find them from the article.
6 REPLIES 6
Julius_Loman
DynaMight Legend
DynaMight Legend
You will need to enable it first in your tenant in Settings -> Monitored technologies:
It is disabled by default. After enabling, your oneagents will listen on tcp and udp ports for the statsd and metric pipe data. Ports are 14499/tcp (metric pipe / line protocol) and 18125/udp (statsd).
sia_h
Dynatrace Pro
Dynatrace Pro
Hi Gary,
If I am not mistaken we'll have documentation available very soon.
Sia
sia_h
Dynatrace Pro
Dynatrace Pro
Hi Gary,
Happy to announce that it's live:
https://www.dynatrace.com/support/help/shortlink/extend-metric
Sia
Thanks so much Sia!
The above link does no longer work, but through the Metrics | Dynatrace Docs section you should be able to get there anyway: https://www.dynatrace.com/support/help/how-to-use-dynatrace/metrics
Kind regards, Frans Stekelenburg                 Certified Dynatrace Associate | measure.works, Dynatrace Partner
I updated Sia's reply with the latest working link on metric ingestion.
