Monitor Prometheus metrics to Dynatrace : does it consume Davis data units ?
you-sun-lux_ea
Visitor
ChadTurner
DynaMight Legend
DynaMight Legend
I would recommend signing up for this power Demo Session:
https://info.dynatrace.com/global_all_wc_power_demo_extend_kubernetes_observability_15684_registrati...
You would be able to pose this question along with additional ones to a Kubernetes and Prometheus Expert!
-Chad
AntonioSousa
You should consult this page:
https://www.dynatrace.com/support/help/reference/davis-data-units/
If you are ingesting through the API, it should consume DDUs:
If you are using Kubernetes, some specific rules seem to apply for now:
Antonio Sousa
