Change chart background color based on thresholds
mkulov
Organizer
Is there a way to change chart background color based on specific thresholds/metric values?
For example I would like specific chart to turn Red if the value on the chart drops below given value.
Thank you,
Martin
Digital Performance Optimizer
6 REPLIES 6
ChadTurner
DynaMight Legend
DynaMight Legend
@Martin K. This is currently not available in the product. Id recommend tossing in a RFE if your organization will need this functionality.
Request a RFE:
https://community.dynatrace.com/t5/forums/postpage/board-id/DynatraceProductIdeas
-Chad
dave_mauney
Dynatrace Champion
Dynatrace Champion
Are you a thrill seeker who thrives by being on the cutting edge and love using Chrome to access your Dynatrace dashboards?
If you answered yes to both questions, I would suggest trying out this Chrome Plugin.
https://chrome.google.com/webstore/detail/dynatrace-dashboard-power/dmpgdhbpdodhddciokonbahhbpaalmco
Holy cow that is awesome, first time seen it. This is awesome.
The math and Sankey is awesome!
dave_mauney
Dynatrace Champion
Dynatrace Champion
Yes, I just learned about in the last week or so, and had a great internal session about it this week at our virtual services conference. The Sankey is really awesome, math is great, coloring based on thresholds...all very cool stuff.
Hi all,
If you will use Single value or Table views you will find a switch called link background to thresholds that will answer @mkulov old request.
Just wonder why its shown up in different sections in each of this 2 options 🤔
HTH
Yos
