Exclude dimension values
mkulov
Organizer
Hi all,
Is there a way to exclude specific dimension values when creating Custom chart.
For example I would like to exclude add hard disk names named "system" when showing Disk available % metric:
Thank you,
Martin Kulov
Digital Performance Optimizer
Julius_Loman
DynaMight Legend
DynaMight Legend
Unfortunately, filters are "include only". So you have to specify all the mountpoints you want to see in the chart.
julien_duhamel1
Participant
hello Martin,
It's possible to exclude the monitoring supervision :
You should able to remove "system" partition.
Regards
Julien D.
