• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Dynatrace /
  • Dynatrace Open Q&A /
avatar image
Question by Erik E. · Oct 20, 2020 at 06:38 AM · installation mobile monitoring network permissions
React Native Certificate
I trying install dynatrace in react native and all running smooth. But, I use plugin truskit for security in apps. How to I get certificate Pin SHA256? I has been trying Pin SHA256 with domain Dynatrace, but my problem cannot communication with api Back End. Is there any solution ?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Paul S. · Oct 20, 2020 at 07:26 AM
Hi Erik,
We need some more information from you.
Do you have trouble obtaining the SHA256 key?
Or have you succeeded in pinning the certificate but failed to establish a connection afterward?
Can you please describe what you already tried, what worked and what did not work.
Are you trying on Android or iOS?
Comment
0 Show 2 · Share
avatar image Erik E. · Oct 20, 2020 at 08:56 AM 0
Share
I can't get the sha256 key used by dynatrace. I've tried using the sha256 key from the dynatrace.com domain and it doesn't seem to work using the dynatrace.com key. This incident happened on iOS. When I tried to disable trustkit, the React Native dynatrace plugin was running normally
avatar image Patrick H. Erik E. · Oct 20, 2020 at 02:31 PM 0
Share
Hi, what is the SHA256 key needed for in TrustKit? Is there a documentation for that API you need it for?
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
34 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Network Security Concerns
Unable to instrument on apk file
Install OneAgent without WinPcap component
chart with aggregation customized
Use Oneagent as a beacon endpoint to monitor Mobile RUM
Forum Tags
mobile monitoring dotnet iis chat kubernetes servicenow amazon web services feedback mysql mainframe application rules rest api cassandra dashboard oneagent sdk cmc waterfall chart application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo opentelemetry integrations activegate auto-detection high five award uem webserver usql iib test automation license ios news migration management zones ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming resource javascript appmon ai availability tipstricks automation extensions diagnostic tools session replay permissions search davis assistant auto-update faq documentation problem detection http monitors easytravel apdex network docker tags and metadata cloud foundry google cloud platform synthetic monitoring lambda process groups account usability dynatrace saas gui paas openshift key user actions administration production user actions postgresql synthetic locations upgrade oneagent security Dynatrace Managed user management python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting performance monitoring NGINX action naming geolocation linux nam installation error reporting database mission control apache slo mobileapp RUM php azure purepath davis scripting aix nodejs android
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
