Does new Dynatrace have cpu and memory utilization metrics for MacOS server?
steven_schneide
Contributor
4 REPLIES 4
JamesKitson
Dynatrace Guru
Dynatrace Guru
MacOS is not a supported operating system so you wouldn't be able to an install a OneAgent on such a server: https://www.dynatrace.com/support/help/shortlink/supported-technologies#operating-systems
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
While OneAgent does not run on MacOS, Dynatrace now also supports Telegraf metric ingest, which means you can run Telegraf on your Mac Server and send metric into Dynatrace. See help docu here:
https://www.dynatrace.com/support/help/how-to-use-dynatrace/metrics/metric-ingestion/ingestion-metho...
Best greetings
Wolfgang
ChadTurner
DynaMight Legend
DynaMight Legend
@wolfgang_beer , @JamesKitson  Just to bring this question back up now two years later, Has Dynatrace provided a monitoring solution for Mac? Mac is based off of Unix and Dynatrace supports Unix but its unclear if that commonality will provide the ability to monitor the Mac Sever.
-Chad
No, still see here:
https://www.dynatrace.com/support/help/technology-support#operating-systems
Telegraf as I answered back then runs fine on my Mac, though.
