Authenticate users using 2-Factor Authentication
In this case, the prospect is specifically asking can their DT Managed use 2-Factor Authentication?
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Yes but only when you integrate with SSO that supports that. E.g. Azure ADFS
Senior Product Manager,
Dynatrace Managed expert
