26 Nov 2020 08:42 AM
is anyone adopting the "Fastify" framework for Nodejs?
https://www.fastify.io/docs/latest/
Is oneagent compliant with this framework? We are doing some tests and it seems services are not recognized when we use this framework.
Thank you
09 Dec 2020 09:41 PM
Here are the supported technologies https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/?_ga=2...
Anything outside of that, its not a guarantee that it will work. Were you able to get it to work?
