HTTP Monitor default timeout value
roberto_ravo
Guide
I've looked in the documentation but I was unable to find this kind of information: does someone know which is the default timeout value for HTTP Monitor requests?
Thanks!
Roberto
4 REPLIES 4
AntonioSousa
I believe it's 10 seconds.
Antonio Sousa
Tomasz_Wozniak
Dynatrace Mentor
Dynatrace Mentor
Hi Roberto,
The default connect timeout is set to 5 seconds.
The default socket/read timeout is set to 10 seconds.
We're working on making it configurable per monitor.
Tomek
This can now be configured per request using the 'Adapt request timeout' option. https://www.dynatrace.com/support/help/how-to-use-dynatrace/synthetic-monitoring/http-monitors/confi...
Thanks for sharing this. Helpful.
Alex Romanenkov
DT_NGINX_FORCE_UNKNOWN_VERSION_INSTRUMENTATION=1
