Failure messages on purepaths
service_apms2
Participant
Hello
Is there a way to get the number of failures with a specific message
Example :
Failures with message RPE560FS09
I think we had this option in appmon
3 REPLIES 3
JamesKitson
Dynatrace Guru
Dynatrace Guru
You can create a calculated service metric either based on the count of request that see that or on the count of the exception and filter it down to that specific message:
You could also define a 'split' dimension to split on the message value but I would make sure you have the necessary conditions for what you're interested in so you don't consume many additional DDUs unnecessarily.
Thank you that was very helpful
MARCOS_ANZAI
Visitor
Hi everyone!
Based on this question, I would like to know if there will be any new feature such as applying message filter from Failure Analysis or Purepath tool.
Thanks in advance!
