Hi all.
Wich command do I have to execute on the Linux hosts to verify the communication to the AG is correct; I use the default port 9999.
Thanks in advanced.
Jose A
Answer by Radoslaw S. ·
You might want to check
curl activegate:9999/rest/health
Yes... I've used "activegate" as a placeholder for the address.
