Filter problem for Process group metrics
parksm
Participant
I'm an engineer in Korea.
Our customer wants to use the "Process count per process group" metric on the custom chart.
As I checked, this metric can only be applied with a tag. I want to filter the names of certain process groups without using tag. However, I can't even enter text.
Both SaaS and managed environments show the same symptoms as the metrics associated with the process group.
How can I apply filters without tagging only one particular process group?
Anonymous
Not applicable
Well i don't recall this working this way actually. Im testing in 204 and 206 and both are the same, i was pretty sure that you could select an specific entity via dimension...
Any way, if you use the new Explorer to create the widget, you can select an specific process via filtering.
And then add it to the Dashboard.
Hope it helps, cheers.
