MongoDB Driver for JAVA
kevin_mortelec2
Newcomer
we have migrated all the MongoDB drivers for java to 3.12.3 however looking at the technology support documentation, the drivers are supported until 3.11 do you have any idea when the 3.12 driver will be supported?
ChadTurner
DynaMight Legend
DynaMight Legend
Hey @Kevin M. were you able to get any information on this? as you mentioned 3.11is the last documented version on the support site: https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/?_ga=2...
-Chad
